ak49er
- May 13, 2009
- 26
- 0
Greetings.
I have a 1976 Hawaiian Jet Boat, powered by a Ford 460, (8.5:1), unknown cam, with a complete MSD Ignition, Barry Grant Mighty Demon 850, on top of an Offenhasuer 360 Tunnel Ram with a single carburetor top plate, breathing through Basset Classic, long collector headers with a Hardin control valve. I also am running a Holley Blue Electric Pump and regulator @ 6-6.5 psi.
A Raw Water Bypass Thermostat System cools the motor. Assuring low block pressure (12-16 psi) full block volume, and regulated temperature. It runs cool and full, as I like to say.
I am aware of the inherent fuel delivery problems of this type of induction setup, and have plans to remedy that by adding a lens of epoxy to the inside of the outer four intake runners, to effectively reduce the volume, while increasing the velocity to match the fuel charge of the Inner four intake runners. It is a lot of work, but I really like how this setup looks, and my drag racing days are long gone.
In the interest of performance and throttle response, I added a 1:1 linkage to the Mighty Demon, in place of the stock progressive linkage. As I did this I rebuilt the carburetor, adding new gaskets, 6.5-power valve, and resetting everything per the BG instruction manual, including float preset, transfer slot reveal, idle screw settings, and Idle Ease settings.
I called the BG tech department and asked if now, that I am making the Pri. And Sec, open at the same time, do I need to balance the carb, i.e. make both Pri. And Sec main jets the same, make both the accelerator pump cam the same, and either add another power valve to the Pri. Metering block, or just remove and plug the power valve on the sec. and also if I needed to make both the Pri. And Sec. transfer slots reval the same.
His answer was simply no, add the linkage and run it.
This however does not make mechanical sense to me, now that both sets of butterflies are opening at nearly the same time and rate, and flowing equal amounts of air, but getting different amounts of fuel.
1) Wouldnt I need to assure that the main jets are all the same, all the way around?
2) Shouldnt I assure that the accelerator pump cams are the same profile and setting?
3) I know exactly Jack **** about power valves, but wouldnt that circuit need to matched by either adding or omitting another Power Valve? And what would the correct power valve be?
4) And wouldnt I need to set the Pri. And sec. transfer slots to the same position?
5) The Pri. And sec. floats appear to be the same, but carry a different casting number , should these be matched too?
Everything I thought I understood about carburetors went out the window after talking to the tech. department rep., and I would like a second or third opinion.
Does anyone have any experience they could share?
