BadBlown572
A/B Team Liaison
- Sep 18, 2007
- 1,930
- 7
Well, some people have asked me to do a step by step deal on what it is that I do to build a boat. It is definitely time consuming and not something that can be easily explained. So, what I will do is to try to walk through some of things that are done to complete a boat.
Step 1: Start with a blank hull.
Step 2: Cut out your drive location & set it up. Very few things must go in one exact spot on the boat. Electrical components, fuel lines, cables, etc. can all be changed around. The Gimbal or the intake MUST be set exactly in the right spot. Once that is done you rig around it.
Step 3: Once that is put in place, I like to put all of the hardware on the boat. Since I build the wire looms for each boat, I have a little bit of flexibility on where I am going to put things. The best way to do it is to put blue tape over everything and break out your fine line Sharpie. Draw the gages, draw the switch panels, draw your handles, etc... You can see what it is going to look like before you are done. MEASURE FIVE TIMES, CUT ONCE!!! Boats are not very forgiving on mistakes!
Dash
Rear Grab Handles
Cleats: The Accon pop up cleats come with a backing plate. I also use it for my template and it works out awesome.
Step 4: Cut the boat out.
On the cleats, I always drill the anchor holes first. So, drill away
On the cleats, some people like to use a jig saw, I personally like to use a hole saw. I drill three holes in the center staying within my template pattern. Make sure that you pre drill the pilot holes prior to drilling down and through. Depending on the size of the cleat, you usually use a 1" or a 1 1/8" hole saw.
Dash
Rear Grab Handles
